I applaud Sandisk for the recent changes to
firmware of my Fuze. It shows that Sandisk
is aware of what customer’s needs are and
willing to keep it’s customers satisfied.
Here are a couple of small requests. One is
Specifically for the Fuze, the other one is a
general request – perhaps for the “Fuze2”
- Alarm function. I have a Cowon G3 that is over 3 years old
that has this function. It also has the “sleep” function recently
added to the Fuze. I am able to select Alarm: on/off, then
either radio or music, then wake time- and how long the device
will play, and also a one-time alarm or every day. THIS WORKS
GREAT – and one of my favorite features of this great little player.
This should not be difficult at all to implement. At most only a
few hours programming to the next firmware release.
- User replaceable battery - It would be greatly beneficial to be able to
have a user replaceable battery. What are my reasonable options
now when the internal battery fails? Either send it in – or throw it
away and into the landfills.
Implementation: Use an integrated battery something similar
to the way batteries are added to notebook computers. a very
small battery simply snaps onto the back of the player and completes
the case of the player. When a battery is dead, it would be a 15
second procedure to remove one battery and replace it with another one.
Surely this would not add all that much to the size or weight if done in
this manner.
THANKS !!!
OK, while I’m asking –
how about playing standard FLV’s from YouTube
wifi access to intenet Radio
ability to record to external SD card
ability to read .pdf files
ability to edit the file name — would be nice after a voice recording
a calendar with sync ability and contact list (names,numbers)
