Maybe some one can post more info about the regions? it depends on what region you chose in the fuze? And btw here a response from sansa support about the replay gain bug; Fuze firmware update 02.02.28 bug. Recently you requested personal assistance from our on-line support center. Below is a summary of your request and our response. If this issue is not resolved to your satisfaction, you may reopen it within the next 7 days. Thank you for allowing us to be of service to you. Subject Fuze firmware update 02.02.28 bug. Discussion Thread (Cezar Ciubancan) 10/14/2009 04:39 AM Dear Denis, Thanks for emailing SanDisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product. We have tested many times the firmware on different players and opperating systems and there was no issue encountered. Please explain us what exactly is the issue. Also if you can attach 2 pictures of the player so we can see the problem. Please refer to your http:// SanDisk Global Customer Support (Hebrew) home anytime to see additional resources from Sandisk. Also, you can visit http:// Support | Western Digital, our online So some one with v2 fuze have to contact them with images.
I have tested Replay Gain on my V2 in combination with each region with absolutely no success.
I did try to take pictures, but the camera on my phone will not focus on the fuze screen.
Message Edited by arg on 10-14-2009 03:22 PM
Sorry if I repeat the news from a separate topic - some people (including me) report sound distortion and lower volume level in the new firmware. I reverted to the previous version and all those problems disappeared. (fuze v2) Unfortunately the enhanced undocumented sensitivity of the radio in the new firmware also gone.
Too much problems i see? So you have to contact them and report it, about the replay gain, you can take shot of sansa updater to show you have v2 fw, and also shot of what happen to the fuze when mess with replay gain. And as i can see all that problems only with v2 ?
@ namiSWAN, one would have thought the developers are able to read this forum - after all it is set up by SanDisk, that is by the Company itself.
To contact them, it is too much hassle. Besides the SanDisk customer service speak poor English and there is no guarantee that your efforts would be taken care off. My guess is that SanDisk sacked the old developers team due the the economic crisis hence this kind of firmware. It is just a guess.
Personally I’ve just reverted to the previous firmware which sorted it out.
And. yes, you are right it is so far V2. Would be interesting to hear from the proud owners of v1. (those are lucky sods, they can move to the RockBox…)
Improper Replay Gain processing can certainly be the culprit of both symptoms.
I update my Sansa players manually.
I’ve had no serious issues (yet) with my V2 4Gb Fuze with 02.02.28F
The only issue i’ve encountered so far is that I can’t set a pregain value for replaygain different from 0.
I haven’t noticed any radio enhancement, nor sound quality problems.
Mmm that’s weird, some people having serious issues and some others whithout them. But all the issues seem to happen in V2 fuzes.
After factory reset, entering the Replay Gain option screen has been hit or miss. Sometimes entering the Replay Gain option page causes a white screen, other times it will show a Pre-Gain of 0.0 dB with the rest of the values being blank.
I have noticed that if I manage to enter the Replay Gain option page (which appears to be entirely based on luck) and save the values, I can re-enter and scroll through the Pre-Gain values without a problem. If I manage to enter the Replay Gain option page after factory reset and scroll through the Pre-Gain values without saving them first, it will white screen as soon as I scroll to one of the blank values.
Message Edited by arg on 10-14-2009 05:43 PM
@arg wrote:
Improper Replay Gain processing can certainly be the culprit of both symptoms_______________
Nope. I never use Replay Gain.
Message Edited by Etoja on 10-14-2009 03:11 PM
As far as I know, there are absolutely no problems with the v1 firmware. I have tried to get it to go white with replay gain, and have not seen any issues with sound. I don’t even get how replay gain works anyway, so it wouldn’t even matter anyway.
I does look like the problems might be related only to v2. There are two different processors from ARM for version 1 and 2, and it affects the firmwire. There might be also some hidden flaws in the v2 - I’m suprised why they refused to release its specification sheet to the RockBox developers.
the firmware ■■■■■ nothing to help the fuze users.
The last we can do is try our luck with technical support, i’m to not use replay gain but it still not fells like use that fw, because of that bugs is like use beta fw. Actually if i think about it now, they maybe could mess something in replay gain, just because it first added in 26 fw, and btw if they had bad english we could fine some hindi speakers to contact them.
Message Edited by namiSWAN on 10-15-2009 11:59 AM
Depending on the bug with the firmware, Replay Gain processing may be imposed without the setting actually being enabled–even without Replay Gain information added to your music. We really need official confirmation of the problem.
GR8 news guys, here a response from support team:
Subject Bugs report in last 02.02.28 fw for fuze v2 Discussion Thread (Florin Ion) 10/15/2009 05:05 AM
Hello Denis,
Thank you for contacting Sandisk Technical Support. It is our goal to make sure you have all the resources you need to get the most from your product.
I have escalated this issue to the development department in order to find a fix as soon as possible.
Thank you for letting us know.
Do not hesitate to contact us for any further concern.
Best regards,
Florin I.
And here another one:
Subject Fuze firmware update 02.02.28 bug. Discussion Thread (Cezar Ciubancan) 10/15/2009 05:19 AM
Dear Denis,
There have been some issues. We investigated and some of the users encountered problems when updating to the last firmware on Sansa Fuze.
Our technicians are working right now in order to solve the problem. You will be noticed when as soon as we will have news.
We are sorry for the inconvenience. For now , please downgrade the firmware to the previous one.
Please refer to your http://kb-he.sandisk.com/app/home anytime to see additional resources from Sandisk.
Also, you can visit http://kb.sandisk.com/app/home, our online keyword searchable Knowledgebase, to easily find answers to your Technical Support and Customer Service questions for all of SanDisk’s products. Simply enter your search terms and our Knowledgebase will search an extensive database of commonly asked questions as well as our online forums at http://forums.sandisk.com/sansa/ to provide you with the most complete answers possible.
Best regards,
Cezar C.
So cross fingers !!!
and btw, maybe the function iself meke sound distortion to, lets wait for responce from v1 users.
Oh noes…
Link to V1 01.02.26 firmware is here.
Link to V2 02.02.26 firmware is here.
Message Edited by arg on 10-15-2009 10:34 AM
They didnt say if the bug apply to v1 btw, so maybe v1 users too have that bugs?
Best regards,
Florin I.
@namiswan "You will be noticed… " and punished. :) Btw, is it a correct English “you will be noticed”? I would think “notified” is more appropriate.
It’s hard to say what is going on. I would downgrade if I had a V1 just in case, so I provided a link to that as well.
@ssorgatem wrote:
@dunny wrote:
Country code.
If you have a “A”, it’s America. F is france, iirc. Mine is T for Test - has an extra diagnostic menu which includes a really freaky microphone test function
D.
How did you get that? I want too! xD Perhaps changing the “Region” string in the file version.sdk? I’ve to try it
BTW, my fuze reports F, but version.sdk says “Americas” and internally it’s set to Europe/Spanish. Maybe the “F” means Europe?
Message Edited by ssorgatem on 10-13-2009 02:15 PM
Basically, just do a manual firmware update - then extract the .bin file from the zip. I found a file called “fuzpA.bin”. I renamed that to “fuzpT.bin” and then copied to the root of the my fuze’s internal storage. Once installed, head to the settings menu and have a bash at the Diagnostics item. Once running, move through it using the “down” button.
Aside - anyone found a reliable method of getting rid of the slotradio icon? I gather some managed by changing their region, but I have no idea how to do it.
D.
Message Edited by Dunny on 10-15-2009 06:06 PM
