SanDisk Ultra Flip Removable to Fixed bit?
I recently purchased this SanDisk Ultra 128 GB USB 3.0 Dual Flash Drive flash drive, hopping it can be used as a “Win to go” disc, but it’s setted as “Removable”.
Is there a tool (oficial or non official) to change that? Or a way with an hexa editor or whatever?
I would really appreciate any help.
Thanks.
Cheers!.
no there is no tool available and sandisk does not make any Fixed disk drives. If you need something for windows to go you will need to look for a flash drive that is advertised for windows to go. Unfortunately most I have seen are quite a bit more expensive than removable drives.
Thanks for your reply!
I manage to make it work whit Rufus, I guess it’s something.
