Ich habe gestern oben genannte SSD Festplatte geschenkt bekommen. Bei mir ist eingebaut eine Seagate Barracuda SATA 3 1000 Gb. Jetzt ist meine Frage: Lohnt sich überhaupt in mein Pc o.g. SSD einbauen( als System Disk)???
Danke im Voraus.
Danke im Voraus.
i think it would be better if you would post your issue/question in English so all of us can understand what you are talking about.
Yesterday I get paid above SSD hard drive. When I installed a Seagate Barracuda SATA 3 Gb 1000. Now my question is: Is it worth at all in my PC og SSD install (as a system disk) ??? Thanks in advance.
in that case where your system supports a SATA 3 connection then you can for sure upgrade to an SSD drive. you will see much higher speeds with this drive and also less power consumption and noise.
so go ahead and install it in your system to enjoy higher speeds ![]()
If you in fact have the SanDisk Ultra SSD and not an Ultra II SSD, it is only SATA 2.
