SanDisk SSD Plus
https://www.sandisk.com/home/ssd/ssd-plus
Specification
Available capacities3 120GB 240GB
Seq. Read(up to)2 520 MB/s 520 MB/s
Seq. Write(up to)2 180 MB/s 350 MB/s
Product Details
Dimensions 2.75 x 3.96 x 0.28 in. (69.85mm x 100.5mm x 7.0 mm)
Interface SATA Revision 3.0 (6 Gb/s)
Operating temperature 32ºF to 158ºF (0ºC to 70 ºC)
Shock Resistant up to 1500G
Vibration 5 gRMS, 10-2000 HZ / 4.9 gRMS, 7-800 HZ
Endurance MTBF: 1.75 million hours
Product numbers
Americas SDSSDA-120G-G25 – 120GB SDSSDA-240G-G25 – 240GB
Europe/Asia-Pacific/Latin America/Middle East and Africa SDSSDA-120G-G25 – 120GB
3 YEAR LIMITED WARRANTY
This product is backed by a three-year limited warranty. For more information, see the Warranty and User Guide page.
Sandisk seems to have released a newer version of the SSD Plus called G26 or SDSSDA-120G-G26.
What is the difference with G25 ?
Best Regards
the last 3 digits are the packaging code. Packaging has changed but specs should be the same.
I have the same problems with my plus 240gb, SanDisk registered and set the waranty  up for me after several failiers.
Then I couldn’t get my files and documents to transfer over from my disc to the SSD PLUS.
After much backwards and forwards with SanDisk I recieved an email with the new upgrade on.
I downloaded then nothing the Dashboard wouldn’t load fully.
Back to sqaure one in la la land.
Your link “https://www.sandisk.com/home/ssd/ssd-plus” is broken.  I am trying to find an install guide for sandisk SSD Plus 240 GB in a win7 PC. I was directed to the above link and it is dead.  Please assist with how to replace HD wiht SSD instructions.
Here I am again, in my endeavor to get my SSD PLUS up and running.
Alas I’m so fed up with not getting it to work I have sent it back to the seller.
Goodbye to you all who tried to help, but there’s only so much one can do.
I promise myself not to purchase another SanDisk product.
Looking at the forum there are many like myself who have been duped by the advertising bumf.
The link seems to be working now.
Hello my Sandisk is reaching temperatures of 61 degree celsius, is this normal? (
Olá meu Sandisk está chegando a temperaturas de 61 grau célsius, isso é normal?)
<a href=“https://mcd-voice.co/”>mcdvoice</a>
McDVoice: McDonald’s is one of the and leading fast food companies which has its main branch in San Bernardino, California, United States.
https://mcd-voice.co/https://mcd-voice.co/
My 240GB Sandisk SSD PLUS drive has problems, as it only recognizes as Sandisk milpitas 0mb of capacity.
How to recover it?
same here.
turned to 16Kb coaster
BIOS sees it as Sandisk Milpitas, was Sandisk SSD Plus 480GB
with no recovery possible
Why does nobody from Sandisk technical support answer here?
After a few months I have the same error!
BIOS sees it as Sandisk Milpitas, it is a Sandisk SSD Plus 480GB.
SSD shows 16kb! of storage and has this strange name “Sandisc Milpitas SSD”.
No SMART available.
How to recover data?
Linux testdisk sees C/H/S only 1 cylinder!
Need to get my data back!
The same problem!!! Sandisk Milpitas, it is a Sandisk SSD Plus 480GB.
No data available.
I lost a lot of thing 3 months after bought the SSD. No assistance, no information.
did you able to recover your data?
