Sandisk Extreme Portable SSD Keeps Disconnecting
I have a 2TB Sandisk Extreme Portable SSD that sporadically disconnects from several pc or notebooks.
This happens even if I am not active at the computer and not touching it.
So it is unlikely a computer, mechanical or power save problem.
Now I noticed there is a firmware uptate for the V2 successor product describing exactly this symptom.
Is there also a firmware update for my product that I just didn’t see?
Has someone else got this problem?
Will contact support today, but its always good to know if this is a one off problem or not.
Hi @Mike_Sweat
(Get Support for Your SSDs and Flash Products | SanDisk)
Try these
(Contact Support | SanDisk)
Bestest product ever
That sounds odd—if it’s sporadic without activity, maybe a firmware mismatch or power delivery quirk? Could be related to cable integrity too, but if the V2 fix mirrors your issue, perhaps it’s quietly similar—have you cross-checked firmware versions or logs?
