Sandisk 64GB CF cards with different model numbers !
I saw two cards on amazon,both sandisk 64GB 90mbps CF cards but with different model numbers and different prices.
Does anyone know the difference between the two ?
SDCFXP-064G-A91  and SDCFXP-064G-P91.
The first one is for $330 and the second one for $795
Manufactured in 2 different places is all.
Thanks. But considering the price difference, is there a difference in quality ? And if you know where are they made ?
the part are the same. the part number that ends with -A is amreicas retail packaging and the one that ends with -P is Asia pacific retail packaging. MSRP (manufacturers suggested retail price) for the card is $895.99 see link below. That said if a reseller has a lot of stock they can sell the cards for a lower price. one source likely is just a larger reseller than the other and can sell the card cheaper and still have an acceptable profiet margin. That said if it is a private auction I would definatly check the seller reviews to make sure it is not a fake card.
http://www.sandisk.com/products/dslr/sandisk-extreme-pro-compactflash-card-90mbs
Thanks
