Dears,
Please help me out.
I bought some “SanDisk 64 GB Cruer Blade” flash drives.
I am having some strange issue.
when I copy some data on drive, I can see its copied, as If I check the properties of flash drive, it will show the Total capacity, Used and Remaining size, but the problem is when i open the drive and check the properties of the data itself it will not be having same size what is consumed, and even by checking folders , data is missing. It happens all the time.
Formatted the flash drive as:
File System: eFat
Allocation Unit Size: Default Allocations Size
Format: Quick / Full Format
But issue remains same. Even after copying the data if i move the flash drive to another computer, its not showing data even sometimes.
Please help me on this issue. If somebody can forward my issue to SanDisk Technical support, I will be very much thankful.
Regards,
Naveed
K.S.A
