SanDisk 512GB Ultra Dual Drive Luxe Unità flash USB Type-C
Hi guys
I just bought this USB stick but the writing speed is very very slow and the reading is also not fast.
Is there any solution to the problem?
Thank you
Hi guys
Thank you
Faster pc, faster USB port, smaller files. Tweak your AV settings.
Hi ed_p
I have a zbook firefly i7 with usb 3.2 Gen 1 and usb 3.1 Gen 1.
I think it is faster PC with faster USB port.
I don’t understand what you mean for “tweak your AV setting”.
Can you explain?
Many thanks
Some AVs test files being written to all drives not just the harddrive and that includes writing files from the harddrive, where they have already been tested, to USB drives, which is redundant, overkill, unnecessary, etc. Check your settings and disable it if possible.
