I had no problem working with my WD Mybook Duo 12TB on my new MacBook Pro 15. Right now I can’t access to the HDD anymore. It detects on Mac then it starts showing red light on power and raid 0. Any way to solve this problem?
Hi Hman,
I would suggest to disconnect the drive, power cycle and then reconnect the drive. If issue still persists, check the status of drive using WD Drive Utilities.
Hi, I have already tried that. It seems like a heat issue. I can access the harddisk for 10-15mins and the led light shows red after that.
