Recharging question
To recharge the battery can the USB plug just be inserted into a USB receptacle or directly into a laptop … or do you have to plug the USB plug into the provided wall plug? Thanks for reading.
If you use a “charge only” cable, you can plug it into just about any USB port, but ordinary USB2 ports won’t charge quickly USB 3 will charge faster.
I’ve also charged using my iPad charger and an Anker multi-port charger with good results.
appreciate your quick reply. thanks for the info.
Do you have My Passport Wireless? Wireless Pro or Wireless SSD?
You may want to consult these “Battery Charge” Articles as well.
https://support-en.wd.com/app/ansresults/kw/battery%20charge/page/1
thanks for the links. very helpful.
i have the mypassport wireless pro
