Received Error Trying to Format My Book 1230 4 TB USB Drive--Please help
Good morning! I have a My Book 1230 4 TB USB drive that I have been using with Windows 7 for the last 2 years with no problems. I used WD Macrium Reflect to save an image of my Windows drive onto the WD My Book USB drive. Last week, I upgraded to Windows 10 and I was trying to re-format My Book to get rid of everything from Windows 7 and start backing up the Windows 10 environment. I downloaded the new Drive Utilities from WD and received “there has been an error erasing your drive” when I tried to re-format the drive. I then ran the Quick Drive tests, which it passed, so overnight I ran the Complete Drive Tests, which was still at 90% and not moving after 7 hours, so I cancelled the test. I then uninstalled the WD Security application and turned off Windows Defender, I then ran the WD Quick Drive Format and received the error “WD external drive format failed.” Please help. Thank you in advance!
Hi pammywammyv,
Maybe you should try contacting WD’s Technical Support about this.
The link below will allow you to call support.
