I reformatted my hard drive and now i can’t find the application to install the smartware. I have the SES driver installed and i still can’t figure out how to download the software. Please help
Use the link below, it will help you to restore the WD Smartware application:
If you are "just " looking the WD SMARTWARE software the you can use this link:
Install it and you should be good to go.
also, make sure that you have .net framework 4.0 installed, first, or the software will not work correctly.
