When I use my sansa clip in a ramdon mode to listen music, it always play the same songs in the same order. Is this a malfuntion or it is program deficiency?
When you select “shuffle” or random mode, a list is generated of your songs. The Clip will play through this list.
If you turn off the player and restart, the list resumes.
You can build a new list by toggling “shuffle” off, and back on, and it will build a new list.
Bob ![]()
