Question on replay gain on the sansa fuze.
Hey people,
IM getting a really good idea at this awesome new feature.Im currently analyzing the volume of my tracks using MM.Is syncing through MM the only way to get replay gain on the fuze having the volume leveled through MM?Or what would happen if I drag and drop the files after analyzing the volume using MM?Will the replay gain information be transferred?
Thanks,
SR
@sr_rox wrote:
Hey people,
Thanks,
SR
The gain information is stored in metadata in each audio file.  It is in the file, so transfer method doesn’t matter.
