Firstly I would like to tell you that I am not a native English speaker so please excuse any language problems i might have.
I bought a WD 3200 ME passport about 6 years ago. Everything went fine untill about 3 months ago. I started experencing problems with my micro-usb cable such as I had to move the cable in certain positions for the drive to be recognized.
I bought 2 new cables. Here is the problem, when i plug any of the 2 new cables, the led on my passport is turned on but My computer doesn’t recognize it. I use Windows 7 64bit. The drive isn’t recognized in disk management and also the icon doesn’t show up in my computer. I plugged the hard drive into a laptop with windows xp but still the same result. Also it doesn’t vibrate like it used to or make sounds. I noticed that it usually makes some sounds when it is being recognized by the computer.
I remember once i kept moving the cable and lightly pressed on the passport and my laptop recognized it and I could access the files on it, but that was one time only.
Any help you could give me is much appreciated. Thank You
