Hello All:
I purchased the SanDisk wireless media drive and followed all installation instructions.
Here’s my problem: When I try to tranfer movies or TV shows that I purchased on iTunes, the transfer looks like it’s taking place and it actually shows up on the media drive. However, the transfers have zero content: They show content as 0:00, and nothing will play.
So, while the transfer bar indicates that, for example, 1.1 GB is transferred, when I access the media drive, a film logo appears but, once again, there is nothing there: 0:00, and nothing plays.
Can anyone suggest a solution? I like the drive and would like to keep it, but unless this problem can be solved, I will have to return it as storage of movies and TV content is the reason I purchased the drive.
Thanks.
