Ali21
                    February 18, 2014,  6:09pm
              1
              I want to make a passport for my 1TB WD elements but I don’t know how, I just bought it, I don’t want to make it as “backup”  or anything I just want to put personal files in it, and have a passport on it, so no one can open it.
but here I am having no idea about how to do it,
as you can see it doesn’t give  me the “set up drive” option , why? how can I put a passport on this thing?
                Ali21
                    February 18, 2014,  7:17pm
              2
              I wish I stayed with buffalo, this is so ridiculous, I do not know how to do anything with it.
                Hamlet
                    February 18, 2014,  7:43pm
              3
The WD Elements does not support password protection with WD Smartware. Only WD drives that include WD Smartware will support the security settings.
                Ali21
                    February 18, 2014,  8:19pm
              4
              The seller told me that this product   here   include security settings.
I don’t , how do I solve the problem? Do I  return the product to them? Because if it does not support adding a password then I have no use for it.
                Ali21
                    February 18, 2014,  9:10pm
              5
              How can I Set Up a password on my Western Digital External Hard Drive ? Step by Step
Then the seller lied to you. The main difference between passports and elements has always been software/encryption support from WD.
Take it back. You want a Passport, not an Elements.
