hi,
having a problem with my 8gb clip. Its turning on fine but when i get to the screen where i can play a song. I press play and it wont? ive tried turning it off and on but nothing is happening? can anyone help?
hi,
You may want to try a re-set: on switch in the uppermost position for 15-20 seconds. Or reformat the Clip, under Settings (note: this will erase your content files on the Clip).
Not to be simplistic, but are you sure you are playing the music correctly (and make sure the player on switch is not in the hold position)? You may want to check the User Manual out (a link to it is under the player specifications sticky thread at the top of the forum).
Hope this might help–
ha na its played for me previously it just stopped suddenly yesterday. Its says its playing but the progress bar is not moving and no sound is coming out.
Perhaps a corrupted file/files? Try reloading from your PC?
