Hello everyone,
I just did a clean install of windows 7 professional and have almost nothing on my computer to muddle things up. I did this to see if it would fix a problem I’m having with my external WD Mybook studio II hard drive.
Basically… The external hard drive freezes during transfers when transferring large files, or multiple files that amount to a higher total. By transfer I mean copying it from my computer to the hard drive, or visa-versa. I can usually transfer up to 200mbs worth of information (whether it be one file, or multiple) without a problem. I get very high transfer speeds and its awesome. Also, there is no problem viewing or streaming information from the drive. I can watch video files, play music etc. without trouble.
When I select a file, or multiple files, that equal more than 200-300mbs (it varies), the copying process just stalls mid way through. The lights on the external drive itself also stop moving up and down and just stays solid. Everything else continues to work… in that i can still browse the drive, but the transfer never resumes. When I view the details of the transfer in the copy window, the transfer speed refreshes and slows to a crawl… under 1mb/s… although the progress bar doesn’t seem to indicate there is any transfer happening at all. If I try to cancel the transfer, it just shows “cancelling” indefinitely.
I am using a firewire connection and my external drive is formatted to NTFS.
I’m running windows 7 x64 professional.
Asus P5Q Deluxe MB
4gbs Ram
Nvidia GTX 275
Intel Core 2 Duo Q9400
Fresh Install… so nothing could be interfering…
I really appreciate any suggestions… I’ve been trying to fix this forever and nothings worked.
