Passport Software
Help, just bought WD passport 1T external drive.   Where is the software?
Hello, any included software will be saved inside the Passport. You can also download the latest version of the software available for your Passport from the download section. Check the link below to find your model.
http://support.wdc.com/product/download.asp?level1=2&lang=en
