Hi I am new here but would appreciate some thoughts/help. I have a MacBook Pro running Snow Leopard 10.6 but as I have a lot of Windows software (including Office) running on Windows XP I use VMWare. This works perfectly on the laptop. The question I have is if I buy a Passport and set it for continuous backup will it back up both sides OK? Perhaps I could use Passport with Time Machine. If I did this would it back up the Windows documents OK too? Thanks for your help. Oldkid
Yup
The software is running on the Mac there for it will be no problem since the drive is formatted for Mac
regardless of the applications you use the files will be backed up
