Passport Essential SE not recognized
I have a unique situation.
I just purchased a “My Passport Essential SE” 1TB.
I plugged it into my desktop USB and it tells me it’s locating the device driver.  After a few seconds, it says that it is ready for use but I cannot find it through “My Computer” or “Disk Management”.  My desktop is Windows Vista 32-bit.
I then plugged it into my laptop, same operating system and it works fine.  I also took it to work and plugged it into my XP desktop and it worked fine as well.
Any thoughs because I am VERY perplexed at this one.
Thank you in advance for any help,
Mie
It sounds like a power issue a lot of PCs use barely adequet power supplies. Did you try different ports on the troublesome PC? Also try unplugging all unneeded USB devices. They do make a power boost cable for these drives, it uses 2 usb ports on PC,
Joe
Thank you for the response Joe.  I have tried all available ports (3 different ones).  I have also attached other WD externals I own and they work fine.
I was not aware of the power booster.  I will have to locate one.
Thank you.
I know it’s on the WD site but I cannot find it. Try calling customer service.
Joe
