I have a MacBook Pro M1. Two identical Anker Hubs, one plugs into the left USB C port, one plugged into the right USB C port. Both disks are WD 5TB My Passport Ultra. The disk on the left port blinks constantly , the disk in the right port only blinks when in use. I had the second drive replaced under warranty, WD sent a “Passport 260F” this dive blinks only in use. the other disk is “Passport 260D”, it always blinks. Was there a firmware update that might cause the ?
Hi @Wazool,
Have you opened a Support Case? If not opened, for more information, please contact the WD Technical Support team for the best assistance and troubleshooting:
https://support-en.wd.com/app/ask
Hi Keerti_01,
No I haven’t opened a case yet, I was hoping the community might have see this already. I guess not. I’ll open a case.
Thanks
