it seems like my passport is stuck,for the past 56 hours its been saying 74.4 gb backed up of 81.7gb…why wont it back up the rest?
is there an otion for me here?
Thanks
Thanks
Hi there!!
First things first: How are you backing up your files? Are you using Time Machine? Are you Using Smartware? o.o
If you are using Smartware, when you compare the categories on the Home tab (NOT on the backup tab), do the match in nombers except for system? If they do, then the backup was completed.
