I’m having a recurring issue with my Acer SF314-54 laptop equipped with a WD Blue SA510 SSD that I installed recently.
Issue:
The laptop boots and works fine initially. After using it and leaving it idle for about 20-25 minutes (this is an average, could be more or less), a blue screen appears briefly and then the system restarts and shows a black screen with the “No bootable device found” error. To use the laptop again, I must manually restart it.
What I’ve tried:
- Updated BIOS to latest version (1.18).
- Applied all Windows and driver updates.
- Used SanDisk Dashboard to check SSD health and confirm firmware is up to date.
- Verified and reseated the SSD physically to ensure a solid connection.
Also, the SSD is brand new. What could be causing this issue?
Thanks!
