i just bought myself a my passport esential SE 1tb drive, and had a quick question.
I’ve taken off all the extra software etc since I don’t plan to use it, and have coppied it to my desktop just in case.
Now, for my question. The hd shows that 300 something mb are still being used. Is it ok to format the drive in windows xp’s my computer? Or will this damage something. I just want to use all available space and back up files myself. Will formatting the drive allow me to do this?
Hi there!! You can format it to clean it, but it will always show some space as used/missing, which is normal as long as it shows 0 files inside, i.e. a drive that is 1tb will most likely show 930GB
If you can see the drive in Windows explorer, you can rename it to whatever you like. Just right click on drive icon and choose rename from the pull down list.
