New WD Passport 3TB (25E2 Media) will not erase to partition
Hi all,
I just bought a new New WD Passport 3TB and will not erase so I can partition.
I am wanting to partition with ExFat to use on both a mac and a windows machine.
I am using a Mac with the OS Sierra. and attempting to
  • HD is recognized
  • I am able to go to disk utility to start the process.
However when I click erase, I get an error process failed "the disk is too large to be supported by the given partition scheme:
Any suggestions?
Hi mksm ,
Probably you can restart the mac and then try to format the drive in exFAT. Moreover, you can run a First Aid diagnostic test on the drive to check its functionality.
Thanks!
I had the same problem.
When I tried to change the selected drive to the most right one, it did work for me!
