Need driver for non internet desktop
Hello.
I am looking for a driver download for an older My Passport (4-5 years old), and the model number has been worn off, that I use on a system that does not have Internet. I want to download the driver then transfer via USB drive to the other CPU.
The problem is, I cannot find a download for this. Everything I have found says Windows 10 will find the drive automatically. This would be correct IF it was Internet-ready, and it is not.
Can somebody steer me in the correct direction as to where I can locate this file??
You posted this in the wrong forum. This is for the My Passport WIRELESS drive.
^= = = Mike is correct. Wrong forum.
However. . . . these are pretty generic drives. What O/S is the disconnected machine running? Have you tried simply plugging in the drive and seeing if it works? You can plug a USB2 drive into a USB3 port, and I would expect it to “just work”
Hello.
So sorry. My bad
I moved the post to the correct board.
Windows did find the driver. However, there was an error.
The following is the error:
Windows found drivers for your device but encountered an error while attempting to install them.
WD SES
The hatch for the file is not Present in the specified catalog file. The file is likely Corrupt for the victim of Tampering…
If you know the manufacturer of your device, you can visit their website and check thee support section for drivers.
Okay. Windows found the driver however there was a bear loading.
Windows file drivers for your device encountered an error while attempting to install the.
WD SES DEVICE
that hash for the file is not present the specific catalog file. The file is likely corrupt but the victim of temporary
if you know the manufacturer device to visit their website and check the Support section for drivers.
go there to download the SES driver. As I remember you don’t need the SES drivers to get the device running on Windows unless it is Windows XP.
