MyPassport Wireless not backing up on second laptop
I have a new 2TB Wireless Passport which is set up om my Vaio and has performed a backup via USB on my Vaio using WD Smartware. As far as i can see this has backed up properly and the files are visible through iphone app.
I downloaded the WD Smartware onto my wife’s Vaio to try and back up her computer via USB and Passport read the files and I duly pressed enable backup button but the download just doesnt start. I left it for a good while and tried rebooting etc but nothing. I had to press disable backup to disconnect and the eject device safely button.
I tried this afew times but it wont start back up.
Any suggestions gratefully received.
Thanks
Hello and welcome to the community,
I recommend you try uninstalling WD Smartsware and reinstalling it.
