In some discussions (e.g. this one and some others) it is mentionned that the external drive MyBook Essential (the models with hardware encryption) performs disk encryption at all times, even when the user has not taken any steps to enable such a behavior.
I have not installed Smartware, much less enabled any passwording of the data on the drive. If the information above is true, trying to retrieve the information from the disk by removing it from the enclosure wouldn’t work, its data would be unreadable.
Is there any reason for this?
If I only use the drive for external storage, and not a backup for sensitive data, this automatic encryption would be useless, and even problematic if I ever needed to retrieve the data from a dammaged enclosure (hasn’t happened to me, knock on wood).
Would a second enclosure be able to decrypt the contents after insertion, or do each enclosure boards have different internal hidden password independent of any user-entered password?
In the link I gave above, many people found themselves locked out of the drive, even without having used a password or Smartware.
Was there any definitive solution found, without using Smartware? Was it a firmware defect?
It would be annoying to be locked out of a drive, when one didn’t even set any password or installed Smartware.
Even more annoying not beeing able to remove the drive from the enclosure to retrieve the data (of course one could make backups… but obviously not on a MyBook Essential since there would be a chance of a wrongful lockout!).
Anyways… This is all disconcerting, and the question above still begs to be asked:
Is there any reason for WD to silently encrypt a drive when the user doesn’t even want to enable it by password/smartware?
(I didn’t see in the documentation where this detail is revealed. I only read that the data will be encrypted when smartware is installed and a password given by the user.)
