My WD Passport 1TB problem
Hi there,
I just purchase 2 unit of 1TB My WD Passport external drive. Both I connect it to 3.0 USB port of my laptop. But when I see at computer management setting, one of my WD passport shows online and another one shows offline with this message "Offline ( The disk is offline because it has a signature collision with another disk that is online) ".
I don’t understand what is this error message means about as my both 2 unit Transcend external drive when both connect to USB port 3.0 both can detect and I can use both also without problem.
Please help how do I configure my both 2 unit of 1TB My WD Passport external to running at the same time.
Thanks.
A signature collision issue can be easily solved.
Sometime you only need to right click and select online for that drive.
Other times is required to assign a different drive letter since the second drive is trying to use a letter that has been taken already by another unit.
There are multiple threads on the community that talk about the same Windows issue.
http://community.wd.com/t5/WD-Portable-Drives/multiple-passports-signature-collision-solved/m-p/7161#M308
http://community.wd.com/t5/External-Drives-for-PC/how-to-fix-signature-collsion/m-p/46964#M2343
