my WD external hard disk unlocker not working. While connecting external hard disk, my laptop getting hang, WD unlocker not opening…plz post any solutions.
Hello ARAVINTHRAJ,
Have you tried it on a different computer?
yes i tried so many times, the follwing things are happening, while i connecting my HD in my lap
- Slow unlocker appear on screen (the window that pop up so you can enter password)
- It became somewhat blurry after I entered the password, kind of lag. After few seconds, it will shows ‘Invalid password’ or ‘Not responding’. Or WD Drive Unlock.exe has stop working.
Hi ARAVINTHRAJ ,
Maybe you should try contacting WD’s Technical Support about this.
http://support.wdc.com/support/case.aspx?lang=en
ok i will try and get back to u shortly.
the problem not yet solved
