For some reason i cant download sansa media converter, im using a MAC OSX 10.3.9, is there another converter out there i can use? (i can upload music just fine) thanks for anyones replies.
p.s. i care more about the photos
You can just click and drag pictures (I suggest that they are jpegs)
Message Edited by gabe565 on 07-31-2008 09:49 AM
SMC is, unfortunately, only for Windows.
As, gabe said, you can just drag photos (jpg) to the Fuze. The only catch is that there is a size limit. Nobody seems to be quite sure if the limit is related to file size, resolution or both. So if you drag a jpg to the Fuze and it won’t display, try resizing it to a lower resolution and it will probably work.
yeah i just found that out about the size of the photo, because i was using jpegs but i didnt know why it wasnt working so i resized it then it worked. so now can someone tell me what about the videos? i tried dragging like minute long AVIs and MPEG-4s but it still wouldnt work any ideas anyone??
