My Passport western digital 500GB cannot be recognized by my computer. I was copying a data from my laptop into the external drive when I received an error message that copying cannot be completed. Since then when I plug the drive into my laptop, it is not recognized by the computer even though the indicator light on the drive keep on blinking.
Please, cannot someone with an idea about what going on help me out.
First try to get help from WD support personnel. If that fails,try following these guides to determine whether you could fix your issue on your own. If not, your drive may be suffering from a hardware fault.
Note: Click the Kudos star to say thank you for helpful posts. And be sure to come back to click the ‘Accept as Solution’ button for the post that solved your issue.
Movno- I just experienced the same thing. After seemingly trying everything within my power, what finally worked was unplugging My Passport from my computer, and then connecting it to my second USB Drive. I don’t know why it worked but it did. I would encourage you to give this a shot if you haven’t already. Hope it helps.
