I was doing a data recovery some loss file on WD passport 2 bt that i had on it… and was trsf them to other external driver I have.
after it was finished… i make sure everything was fine… it was then i unplug it now my wd passport utra is unreadable, i have try the disk mrgment but it doesn’t see it either or WD drive utilities not able to see it either too. I am loss what to do as light is on and flashing…
I recommend you try some basic troubleshooting.
1- Disconnect the drive from the computer and restart the computer.
2- If the computer is a desktop, connect it on the back USB port (directly to the PC, not through a hub).
3- Make sure you hear the connection sound windows makes when recognizes a USB device.
4- Go to "Disk Management” to verify if the drive shows up there.
If the drive shows up in disk management but it is not seen on Computer, then it means the partition is corrupted and you will have to format it in order to use it again. Please note that formatting the drive will delete all data stored on it.
Thank you and now it is working!
