My Passport Ultra - PC to Mac?
I used My Passport Ultra exclusively for my almost dead PC as a repository for photos. Now have a MacBook Pro and Apple Cloud storage. Before loading up even more files, I want to take the opportunity to delete some photo files on the Passport. But can’t seem to do it.
Is there a formatting issue going from the PC to Mac?
How do I delete files from the Passport.
Hi atatexan,
You need to reformat the drive for the Mac as the My Passport Ultra drive File Format for Windows PC is NTFS and Mac supports MAC OS Extended (Journaled) file format.
You can follow the link given below to reformat the drive for MAC.
Thank you very much, Brandon.
Regards,
Charley
after a few steps, it discusses things being erased. Will it erase the entire contents of the external drive?
Hi brianK7007,
Formatting is a data destructive process and it can’t be undone. Recommend to take a backup of important data files before going to formatting of drive.
Yes, this is a formatting issue. Because the drive was used exclusively on a PC, it is formatted in NTFS. macOS can read NTFS drives (allowing you to see and copy the photos), but it cannot modify them—meaning you cannot delete or add files by default.
Here is the quickest way to fix this and delete your files:
Option 1: Back up and Reformat
Formatting will erase the drive completely, so secure your photos first:
  1. Copy your photos: Plug in the drive and drag all the photos you want to keep onto your Mac or into your Apple Cloud.
  2. Run Disk Utility to format it:
  • Press Command + Spacebar, type Disk Utility, and hit Enter.
  • Select your My Passport drive from the left sidebar and click Erase at the top.
  • Choose the format: Select APFS if you only use Macs now, or ExFAT if you still need it to work on Windows PCs. Click Erase.
  1. Move files back: Drag your photos back onto the freshly formatted drive. You can now delete files normally.
Option 2: Use NTFS Software (No Formatting Required)
If you don’t want to move your files off the drive or reformat the external hard drive, you can download third-party software like iBoysoft NTFS for Mac or Paragon NTFS for Mac. These utilities grant your Mac instant “Read & Write” access to Windows drives, allowing you to delete files immediately, move files back and forth, and more. [Related guide: How to fix Mac unable to write to an NTFS drive ]
