My Passport Ultra 2TB Exfat
Hello , i bought a 2TB My Passport Ultra external drive, and because of the nature of my work
( sound engineer ) i formatted it with the exfat format.
I have to be aple to access my files both on Mac and on Windows.
The problem is that on my windows 7 laptop , when I eject the hard drive, it doesn’t shut down.
Does anyone have any clue what’s going on ?
Thanks a lot for your time !!
Hi sabbarth, as long as you get the message that the drive was safely ejected, there should be no problems disconnecting the USB cable.
thanks a lot for the answer I was getting worried that I may damage the hard drive
