My Passport is a 2 TB capacity. I had it filled up and wanted to erase the drive so I reformatted it thinking this was the fastest. Now when I go to My Computer the Passport has a capacity of total size 917 GB and it shows space free of 917 GB. Also next to this icon in My Computer there is another icon that says “System Reserved” space free 65.8 MB and total size 99.9 MB. What happened? How can I correct this so only one icon shows up showing 2 TB?
Make sure that the unit was not partitioned in two and that the other partition doesn’t have an OS installed.
Check on disk management to see how is the drive showing and how many partitions.
Link to disk management:
How to access Disk Management in Windows to manage hard drives
Your 2 TB drive was likely formatted using a system image or disk cloning tool, which copied the partition layout of a 1 TB computer drive (917 GB main partition + 100 MB System Reserved partition) onto your external drive. The remaining ~1 TB of your drive is now sitting as “Unallocated” space. To restore the full 2 TB capacity, you can follow the steps below:
How to Restore Your Full 2 TB Capacity
Note: This process will permanently erase everything currently on the external drive.
Open Disk Management: Right-click the Windows Start button and select Disk Management.
Delete the partitions: Locate your external drive at the bottom. Right-click both the 917 GB and System Reserved sections on that drive and select Delete Volume for each. The drive will turn into one “Unallocated” block.
Create a new volume:
Right-click the Unallocated space and select New Simple Volume.
Click Next through the wizard, leave the size at maximum, choose NTFS or exFAT as the file system, and click Finish.
Once completed, you will see a single icon under My Computer showing the full ~1.81 TB (the actual usable space of a 2 TB drive). This blog is also helpful - How Initialize & Format External Hard Drive on Windows PC?
