My Passport Pro Portable RAID Storage encryption and max drive capability
  1. Am I able to change drives in my My Passport Pro Portable RAID Storage 4TB? I would like to increase the capacity to 6-8TB. Is it possible? If yes, where can I find disk compatibility list?
  2. Is it possible to encrypt this storage in stripe raid configuration on macOS? I tried to encrypt it unsuccessfully.
Thank you
Radek
Hi radospanny,
It is not possible to change the drives in My Passport Pro drive as it is not user serviceable drive.
For More information, You can contact WD Support Team from the link given.
The link below will allow you to call support.
