I have a WD portable hard drive (My Passport). It used to work fine with my laptop. There was a period of time where I haven’t used it. All of a sudden, it doesnt work on my laptop. I’ve plugged my cell phone in and other devices that require a USB connection, which they all work fine. When I plug in the passport, nothing happens. Nothing registers on the ‘computer’ part. I have a somewhat new Dell laptop.
If the drive is not seen when you connect it to your computer then you should try some basic troubleshooting:
1- Disconnect the drive from the computer and restart the computer.
2- If the computer is a desktop, connect it on the back USB port (directly to the PC, not through a hub).
3- Make sure you hear the connection sound windows makes when recognizes a USB device.
4- Go to "Disk Management” to verify if the drive shows up there.
If the drive shows up in disk management but it is not seen on Computer, then it means the partition is corrupted and you will have to format it in order to use it again. Please note that formatting the drive will delete all data stored on it.
