my HDD My Passport 1 TB, don’t work anymore with TimeMachine since the last backup, who was interrupted.
My Mac is under El Captain 10.11.6
Thanks for your help
Have you try to format the drive?
yes, but it is not possible.
Diagnose the dive using WD® drive utility and find the health of the drive.
WD Drive Utilities for Mac
You can also redirect to the given link to check whether the drive damaged or what.
Hi, I’m abroad. I’ll try soon. Thanks a lot
Failed error message.
Wait for the end of the first backup
WD support doesn’t help.
Problem with Time Machine
