I have a 4TB My Passport that I purchased in May 2019. It functions as my Time Machine drive. Up until yesterday, it was working fine. We had a brief power outage, and when the power was restored, the drive did not mount. I have tried unplugging it, restarting my Mac, shutting down my Mac–just about everything. The drive shows up in my Mac’s disk utility app, but it is greyed out. When I try to run “first aid”, I get a message that the drive is not accessible. Is this a hardware issue or something else?
When you connect an external hard drive on Mac, it will show up on Desktop, Finder, and Disk Utility. But sometimes the external drive won’t appear on any of these places. To fix the issue, you can try the below methods:
- Change MacOS settings
- Reset Mac firmware settings
- Fix external hard drive connectivity issue
- Troubleshoot external hard drive
- Recover data from non-mounting external mac hard drive using reliable data recovery software
Further, I suggest you to check the below link for detailed steps to be followed in each method above.
Hope it helps!
If your disk drill external hard drive not showing up it can be just some random issue, but cn be also serious and you might lose some of your important data . This guide https://www.hаndyrecovery.com/external-hard-drive-not-showing-up-mac/ has 5 methods to recover it back without losing important information.
This has happened to me a couple of times as well, and I know how frustrating it can be. If your external hard drive not showing up next time, make sure to save this article: https://www.cleverfiles.cоm/howto/external-drive-not-recognized-windows.html. It offers a detailed, step-by-step guide on how to fix this issue quickly and effectively. The solutions provided are easy to follow, and it will help you get your external drive recognized again in no time. I highly recommend keeping this link handy, just in case
extremely useful
- Try mounting the external hard drive manually:
Restart your Mac, open Disk Utility, select the My Passport external drive, and click the “Mount” button in the upper menu bar. - Update the disk driver and reconnect the external drive:
Open the Apple Menu > System Settings > General > Software Updates and check for any available updates. - Reformat the external hard drive:
Reformatting can fix file system errors. However, please note that reformatting will erase all data on the drive. (Also read: Fixed! External Drive Greyed Out on Mac? Can’t Mount, Erase, Partition )
