My Passport Essentials Wont get detected!
i have a WD my passport Essential 500GB
i got this from India, but I immigrated to USA
is there any way i can get my hdd serviced?
I recently was working on my drive, and next day i wake up to find that my drive wont read on windows,
i panicked and tried to read it on linux and it read it successfully, i backed up all important data!
i rebooted into windows and it still wont detect, running chkdsk /R on the drive resulted in a message That its a raw partition.
I loaded the WD formatter and formatted the drive, it worked great for a day and the next day it wont detect at all
it gets detected when i hold it vertically, but when i start to format it just wont do it giving me an error at about 20%
when i re attach it shows up as an unknown partition
is there any way i can have this serviced in USA???
its a limited edition drive that i won in a competition!
https://www.facebook.com/media/set/?set=a.10150547731345181.650337.841100180&type=3&l=a75075353a
I recommend you to contact WD Support:  http://support.wdc.com/contact/contact.asp?lang=en
