i have a My Passport Essential SE 1 TB 2.0 that is all of a sudden not beinf read by either of my laptops. i have tried several micro usb cables, and nothing! I have not had any trouble with it until now. plzzz help!!! ![]()
Hi
Try accessing to Disk Management ( Start > right click on Computer or My computer if you have win xp > on the Computer Management window click on Disk Management )
If the drive is healthy everything is fine but if the drive is unalocated then you will have to format it.
If you don’t see the drive there then my recommendation will be to replace it.
