In My Computer is visible only drive WD Unlocker. There is possible to unlock disk, but I cannot see saved data. What can I to do? How to repair it?
If you can only see the WD Unlocker it is possible that your drive is locked. If it is locked then you can only unlock it with the correct password. If you don’t know the password then you may try to unlock it 5 times and you will get the option to erase the drive. This will erase the password on the drive along with all the data stored on it.
