I have bought “My passport” 1 TB hardisk. And after taking backup of my laptop data (which is 110 GB only), through WD Smartware, my passport drive is filled upto 600 GB.
Every time when i conect my passport to laptop, backup starts and it backups same data. I dont know how 6 times space is filled?.
If I delete folders created inside WD SmartWare.swstor manually, and re-connect “My passport” to laptop, will it work properly? Will there be any issue after folders.
I have changed the setting from 5 backups to 1 backup only in settings->prefernces.
Should I – (is there any need of it)
copy softwares provided in “My passport” firstly
then completely erase drive
restore softwares of “my passport” and install WD smartware.
(1) yes, i have checked that already have data in my laptop. So there is no harm in deleting data from my passport.
(2) Instead of doing erasing drive, can i just delete folders created inside WSSmartware.swstor folder. These folders are created automatically when I connected my passport to laptop for backup.
(3) after deleting these folders, will I be bale to take backup again of my laptop? Will a new folder be created automatically then?
