hi
i have usb harddisk “mypassport” 320 gb
i was working with it
accidently my pc rebooted
after reboot my passport asking for password
i have never used password system for it
how can i remove it?
plz help me
there is so much data in my hard disk
plz give me solution
thanks
my email id is [deleted]
m waiting ofr solution badly
Hi there… If the drive is asking for a password after a system error… As far as I know, the drive can’t be unlocked without formatting…
Try to contact WD, they may be able to provide more options.
Best of luck!
A couple of people had dumb luck by logging from a different account like Guest account. If that doesn’t work you’re out of luck. Never trust important data yo one drive internal or external no matter who makes it.
Joe
