My Passport 1TB Not showing up in my Mac when I plug it in
Please help. I bought a new my passport (blue) and when plugged it in the first time it showed, but when I tried using it for the time machine it said that there’s not enough space, so I let it erase the content to reformat it. But when I plug it again it doesn’t show anymore. I tried using it to Windows 10 but it’s not showing either. It is broken? What should I do?
Hello, bada386
Well try to follow the instructions mention on the article given below.
If the issue persist then you should try contacting WD’s Technical Support about this.
