Hi everyone,
I’ve just bought a My Book Essential 1T and after I turned it on, the driver install started straight away and was successful. I then started SmartWare and filed in the Registration and Security such as the password. Before I even made a backup of anything, I clicked on the software update which took me through the whole firmware and software update procedure. I followed everything to the letter, such as disable password, check that .NET Framework 3.5 was already installed in my portable, unplug power and USB after the firmware install and then reboot after the software install. I have completed this process two times (an exhausting one I must say) and I cannot get the software to upgrade. The version that still shows is the 1.2.0.20 (the initial one at startup) and the one downloaded from WD’s site is 1.3.0.16. It just keeps showing the 1.2.020 on the right-bottom corner of SmartWare. I suppose that the firmware went ok because it shows 1.20 and something else that it does not show…on the download the version is 2.010(1.0.8.3). I’ve spent 2 hours in this process and it just should not be this way…feeling a bit frustrated by now. Can you please help?
Thank you.
